Not able to remove spaces from ASCII code Hex string
Not sure, but maybe this does the job (I removed the CRC part):
Paolo
Message 11 of 22
(2,288 Views)
here crc.vi is a subvi
Message 12 of 22
(2,285 Views)
This is giving Incorrect conversion
Message 13 of 22
(2,282 Views)
The way i have did is only giving the correct conversion as this solution was given by Mr. Altenbach he knows the datasheet of these strings
Message 14 of 22
(2,280 Views)
Here's what I would do (skipped the CRC for now)
Message 15 of 22
(2,276 Views)
But Sir Desired output is like given in this datasheet i hope you remember sir
Message 16 of 22
(2,271 Views)
As the default values are attached in the VI $ should be 24 in ASCII but using this method its not like that
Message 17 of 22
(2,269 Views)
What is "this method" and what is "that" you are comparing it to? You need to be less ambiguous!
Message 18 of 22
(2,261 Views)
Accepted by topic author Anjaney
I do get a "24" for the $. I haven't inspected the CRC calculation, but maybe something along these lines would do what you want after some more tweaks.
Message 19 of 22
(2,260 Views)
and ir can you please help me with how it reverse will work
Message 20 of 22
(2,257 Views)
