reinitialise/restart a loop when condition is true
Hello, I have a program and at the end, if the number is >0, the condition is true. i want, when it's true, to reinitialise the while and restart it. the while is in a case strusture and in another while. i put the code here. tell me where i am wrong please :) thank's a lot.
(3,079 Views)
I don't understand what you are doing.  You say "if the number is >0", but you are comparing if one array of numbers is greater than an array of numbers {1,2,3,4,5,6}.  If when you convert those comparisons to a boolean array to a number, you see if that is greater than 0.  That is effectively the same as OR array elements.  If any of the values are greater than the corresponding element in  your 1...6 array, then you are true.  You stop the loop and do it all over again.
I'm not clear on what you are reinitializing.  If you want to reinitialize the queue point by point, then you should wire the boolean into that connector of the subVI.
I think you have one or two too many levels to this VI,  What is supposed to happen in the False case?    Other than the very first time this VI runs, and in that event, you wire a true into the shift register and immediately go into the true case.  It will never run the empty false case again.
You should be able to do this with a single while loop!
(3,059 Views)
thank's for the answer.
I just want :
If the "x-y" > to the "array 2" (any value) so i can get a true value. then, if it's true, restart the loop and reinitialise all arrays (exept the array 2). if it's false, juste continue the while loop till it's true.
i don't know if i'm clear for you, i have a little english ...
hope you will understand
(3,055 Views)
Accepted by topic author siwalex
I still don't understand "restart the loop" because the loop would always be running to get new data in the event the condition is not true.
The decisions is to either reinitialize or not.  The loop always runs.
See attached for the simpler implementation.
(3,050 Views)
well done !
that's it !
thank's.
i understand now how to do with only 1 loop 🙂
my thank's to you.
just one question, how to simply done an array of 1000 lines with in all line the number 3?
thank's again. you save me 🙂
(3,046 Views)
Look up Initialize Array.
(3,044 Views)
