07-08-2013
09:08 AM
- last edited on
11-10-2025
01:58 PM
by
Content Cleaner
Hi
I am trying to configure a DAQmx routine where I record multiple analog channels. I am able to create the routine, but I read that there are some problems with multi-channel sampling (ghosting), so I wanted to avoid this.
How Do I Eliminate Ghosting From My Measurements?:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHy6CAG&l=en-US
Which further directs you to;
How Do I Increase Interchannel Delay Using NI-DAQmx or Traditional NI-DAQ (Legacy)?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NFQSA2&l=en-US
However, when I try to use a DAQmx Timing Property Node, I am not able to change the property (see screenshot). I have tried right-clicking and left-clicking and clicking all over. I think there is something I might not understand, but any pointers would help alot! Chaning between Read/Write does not help
07-09-2013 05:44 AM
Never mind! Found the solution in the Knowledgebase 🙂
07-09-2013 05:56 AM
Can you post the link to the KB, which you think is a solution.
07-09-2013
08:37 AM
- last edited on
11-10-2025
01:59 PM
by
Content Cleaner
Of course!
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kFGaSAM&l=en-US
In case that link doesn't work, the title is:
Missing Properties in DAQmx Property Nodes
with Document ID: 3ESBHEL2
