Norma 5000 LabVIEW Driver
Hi everybody!
I'm trying to acquire data from a Fluke Norma 5000 which has 6 channels. I' m using the LNOPA01 library provided by Fluke.
I'm metting with this problem: I can read the first three channels and totals, but I'm not able to read channels from 4 to 6.
Does anybody ever dealt with this problem or ever worked with this driver?
Thanks in advance for any suggestions; any help would be helpful.
Andrea
(3,930 Views)
The zip which you attached is just the official llb driver pack.
You should show your actual VI where you try to read all the 6 channels using the supplied driver VIs.
Attach a snippet or VI, and not a simple picture please.
(3,904 Views)
I solved the problem.
Thank you anyway for the support.
(3,881 Views)
I have the same problem, how did you solve it?
(3,400 Views)
