Non-linear curve Fit
Has anyone implemented an object-oriented version of the Non-linear Curve Fit LM VI? I.e., one in which the data is an instance of the a defined to work with the VI and in which the model function is a dynamic-dispatch member function of that class?
If so, is the code available?
Hugh
(2,635 Views)
I have searched our website, discussion forums and KnowledgeBase articles, and was unable to find an implementation of OO programming for the non-linear curve fit equation. For your reference, here is an article about OO programming:
LabVIEW Object-Oriented Programming: The Decisions Behind the Design
Good luck with your application!
Amanda Howard
Americas Services and Support Recruiting Manager
(2,595 Views)
