No output from Simulink to LabVIEW with Simulation Interface Toolkit
I'm able to send data from labview to simulink, but the labview display doesn't show any output from the simulink model. I've attached two very simple labview and simulink files which gives me this problem. I have the same problem when trying to implement the sinewave example in the manual for the toolkit, no output shows up in labview.
I'm using LabVIEW 7.1 Pro, Matlab 6.5 and Simulink 5.0 on WinXP pro.
(2,924 Views)
You need to have SIT 2.0.2 patch to use LabVIEW 7.1 with the Simulation Interface Toolkit.
(2,924 Views)
