Matlab code in RT
I was running a matlab code using matlab script block, in my local machine. Now, when I run it in RT...the ouput array is empty...ie, Matlab does'nt work. How do I load matlab into RT...so that my RT system can also execute matlab code.
(5,614 Views)
The Matlab script node only works under the Windows operating system. You would need to convert the matlab code to a DLL to call under RT. Perhaps the Mathworks sells a Matlab compiler?
(5,614 Views)
Hi Shreesha,
GregMo is correct. The Matlab script node uses the copy of Matlab installed on the machine, but when running in LabVIEW RT, the Real-Time target does not have that application installed.
Compiling the code into a dll will work as long as is doesn't have dependence on other functions that require Matlab or Windows.
Here's a link to a knowledgebase that will be helpful.
http://digital.ni.com/public.nsf/websearch/0BF52E6FAC0BF9C286256EDB00015230?OpenDocument
Vineet A
(5,614 Views)
