NiFpga_Status_BitfileReadError
I am getting the NiFpga_Status_BitfileReadError when I try to load a FPGA bitfile into a cRIO-9081.  The bit file was build using LabVIEW 2011.  Under Max Software I have the CompactRIO 12.1 and the following LabVIEW Run-Times  8.2.1, 8.6, 9.0.1, 10.0.1, 11.0.1, and 12.0.1.
I believe that LabVIEW 2011 needs the 11.0.1 run-time, so I should have compatible bitfile.
What other issues would give me this error?
(5,920 Views)
Hi Paul_Knight_Lockheed_Martin,
What version of LabVIEW was the bitfile built in?  Do you have an error code associated with the error?  You should also make sure that you have compatible software installed on the cRIO side.
Josh B
Applications Engineer
(5,865 Views)
The error is NiFpga_Status NiFpga_Status_BitfileReadError = -63101;
The cRIO has LabVIEW Run-Times  8.2.1, 8.6, 9.0.1, 10.0.1, 11.0.1, and 12.0.1 installed.
I think LabView 2011 uses the 11.0.1 runtime, so we should be compatible.
Also, I was downloading bitfiles using this a couple of months ago.
(5,859 Views)
Are you using a cRIO-9801 that is running Windows or an RT OS?  In MAX, are you looking at the software installed on a host computer or on the cRIO itself (some of this could depend on whether the cRIO is running Windows or an RT OS).  The error code can also indicate that there is a corruption in the bitfile of that there is something wrong with the file path pointing to the bitfile.  Have you tried loading other bitfiles to the FPGA?  If so, do you always see this error or only when you try to load the one particular bitfile?
Josh B
(5,840 Views)
Josh,
I am using a cRIO-9081 running Windows 7.  The 6 runtimes version I got from the cRIO using MAX.  I have rebuilt the bitfile 3 times and I have double checked the path information is correct.
I don't have anyother bitfiles to try.  I will try and create a simple one and see if I can load it.
Paul
(5,835 Views)
Josh,
I was able to determine the cause of the error.  I had added a newline in the buffer that I created to combine the FPGA_BITFILE_DIRECTORY with the FPGA_BITFILE_NAME to create the absolute path.
I wanted to use the same buffer to display the path to the user.
Trying to get fancy.  Should always keep it simple.
Paul
(5,818 Views)
Excellent!  I'm glad you were able to find the cause of the issue.
Josh B
(5,808 Views)
