Ni max and power supply
Hello everyone,
I am a new LabVIEW programmer, I need to send commands to supply a constant voltage or current to a power supply (Sm30-100 from Delta electronica). Unfortunately, I didn't find a suitable driver for this instrument or any example.
Is it possible to simulate this instrument in NI Max? and what else do I need to achieve that?
(5,127 Views)
In spite of the manual saying it's easy to program, it doesn't really seem that way at all.  If you can use a different power supply - one that uses SCPI to communicate - that would be a LOT easier.
Bill
CLD
(Mid-Level minion.)
(5,080 Views)
thanks for the reply,
I totally agree, The risk of having an error is high. Unfortunately, I am afraid that I have to work with this power supply.
But cant I send These SCPI commands through Ni Max program?
(5,008 Views)
Accepted by topic author Suhaib@961
Hi Suhaib,
that SM30 is a discontinued product from Delta, they offer an replacement (see here). But they still offer service until 2027…
The manual they offer on that website doesn't provide a list of commands for RS232/GPIB remote control. You will need to contact that DeltaElektronika service to provide you with such a "programming manual" for that old device!
Once you know the commands for your device you can send them through MAX or LabVIEW…
(4,995 Views)
Seems like you "program" this thing by using a scaled voltage???  So you have to have a power supply to program the power supply?  😉  And you need a DAQ if you want to record the output values.
It's probably cheaper to buy another power supply.  One that utilizes some kind of programming language.
Bill
CLD
(Mid-Level minion.)
(4,857 Views)
yes, that's correct, the power supply has an analog programming connector. I used an Arduino to supply 0-5v signals to check if I can change the voltage using a potentiometer and it worked. I need to set Voltage/Current and collect those readings.
I think I can manage to do that using DAQmx.
thanks for your support
(4,237 Views)
