Newbie question
In general, I would like to create an executable only version of my VI, so I can run this VI without having the developmental version of LabVIEW installed on the PC?
Message 1 of 14
(3,496 Views)
Yes, possible, though LabVIEW development environment is not required on the PC it is run on, LabVIEW runtime engine is required.
Santhosh
Soliton Technologies
Message 2 of 14
(3,480 Views)
You need the application builder to create standalone applications. (included in some versions. What do you have?)
Message 3 of 14
(3,458 Views)
You have to understand lot more on the LabVIEW Environment.
1. You should have a properly structured Project Files mapped with your Developed Code Module, which will look something like below
2.You need to Create Application (EXE)
3.If you want to install in a PC where no LabVIEW Platform (NI Runtime Engine) you should create Installer.
Note: Input to your Installer will be your application.
Check Below image for better understanding.
Note: You should have application builder license to carry out above process.
Message 4 of 14
(3,386 Views)
Message 5 of 14
(3,344 Views)
hello thank you for the reply.
I have two different LabVIEW developmental installations to work with:
LabVIEW 2020.. Full development system
And
LabVIEW base development system, version 21.0.1f2(64-bit)
Message 6 of 14
(3,335 Views)
And
To use the application builder, you need LabVIEW professional or add the application builder to what you have
You can compare versions, especially the "code deployment and distribution" section here.
Message 7 of 14
(3,318 Views)
The easiest and surest way to find out if you have the Application Builder, is to open the NI Licence Manager and see...
=== Engineer Ambiguously ===
Message 8 of 14
(3,293 Views)
okay thank you very much,
yours was the best help of all
Message 9 of 14
(3,227 Views)
I have LabVIEW 2020,I have a green dot for application builder.
I have a single VI (.vi), I want to convert that to a run time version?
Can I do it?
Message 10 of 14
(3,161 Views)
