Newbie Questions on Labview
This is the way.
Message 21 of 38
(1,459 Views)
@jcarmody wrote:
Like you, I am a big fan of vertical wires (e.g. the 2D array dropping in from the top) and I really hate that auto-routing fights me on that more and more (... and more and more) with each new version. 😄
Message 22 of 38
(1,457 Views)
@altenbach wrote:
I could never stand the auto-routing.  I always have it turned off.
Message 23 of 38
(1,445 Views)
@jcarmody wrote:
@altenbach wrote:
[...] a pedantic programmer who spends 95% of time perfectly aligning and spacing things. [...]
Each object needs to be eight pixels apart.  If there's a wire between them, the wire should just disappear when moved eight pixels.  Containing diagrams must border its contained objects by eight pixels all around.  It's not pedantry, it's what separates us from animals.
Well, I like diagrams to be neat and tidy, but I don't have exact-pixel-spacing OCD.
Message 24 of 38
(1,443 Views)
Did you get your code working?
If you still need help, I would recommend running pre-built tools (all free (or included with LabVIEW)).
Dynamic Signal Generator (DSG) will output sine waves on your outputs. Free Download
Use FlexLogger Lite to record your inputs and the accompanying DIAdem Lite to view the logs. LabVIEW's TDMS File Viewer can also be used to view data stored in a TDMS file.
If you need to write the data to a custom text format, you can write a much simpler VI to read from TDMS and write to your custom format. You can do that without gating your data collection.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 25 of 38
(1,331 Views)
Hi Doug,
Thank you for checking in on me, as this has been a rather frustrating journey, and it's nice to have help! I have been able to create a code with at least mostly working portions (see attached VI), but I'm having trouble specifically with the function generator outputs, as they are either not registering or are not sine waves and not outputting the requested frequency/amplitude. I've attached a snip of my output voltage (AOs.png) which shows the outputs recorded by my .CSV write for the two AO ports (generated in MatLab). ElecIn is AO1, MechIn is AO0, for reference.
In addition, it looks like my DAQ is not collecting data at the specified rate (200kS/s).
I realize I'm trying to sample at high rates, and this may not work well with DAQ Assistant, so this may be one of the major issues. However, I've attempted to apply DAQmx in the past and have been unable to achieve useful results either.
Any suggestions on how to proceed?
Joseph
Message 26 of 38
(1,311 Views)
Accepted by jecunningham@vt.edu
Change Acquisition Mode in Both DAQ Assistant Express VIs to Continuous Samples!
Make sure that the samples to generate is equal in both simulate sine Express VIs and the AI DAQ Assistant. I recommend 20000 samples (to achieve an overall loop rate of 0.1 s).
Simplify your logging. I stripped out logging to csv files and enabled logging in the AI DAQ Assistant block:
The modified code runs, and the logged data looks like sine waves:
Doug
Message 27 of 38
(1,271 Views)
Oh, and make sure you add a timestamp to the file name or find some other way to uniquify the file name so you never (unintentionally) overwrite previously recorded data files!
Doug
Message 28 of 38
(1,263 Views)
Hi Doug,
Thank you for the simplified program and explanation. I am still having some issues with implementing LabView to get the functionality I need for my testing. When I attempt to implement this code, however, I get an error -200279, which says the software's reading too slowly and the buffer overflows. I've heard the way to remedy this is to use DAQmx and simpler functions rather than DAQAssistant and ExpressVIs (though AI may be off-base on that suggestion). I've attached the modified code you provided which is throwing this error (...RespDoug.VI). I noticed when taking a closer look at outputs that it seems like there's still a phase mismatch, especially in the 10 Hz region. It's important I'm able to phase match as otherwise I worry about overaccelerating my equipment with a mismatch voltage jump.
I've also attempted to create a code which takes care of both the DAQmx substitution and the pre-buffer issue while generating phase-matched sine waves within the loop (...SinBuf.VI), but that's also throwing a similar error (-200279, on the AI error branch). I've tried increasing the buffer size, but to no avail.
Finally, I'd prefer to use either .CSV or .txt files for output, as these are easier to process down the line. Working with long waveforms in Excel is... not great, due to character line limits.
I know this is... a lot, and I totally understand if you don't have time to take a look. If you can look at my code and let me know any suggestions, though, I would certainly be grateful!
Thanks again,
Joseph
PS. SineWave and tarray are custom VIs used in ...SinBuf.
Message 29 of 38
(1,236 Views)
After targeting your code to my hardware, I am able to run without any additional modifications and without seeing any errors. Sooo, I think you are close. Since this appears to be a performance issue at this point, try these easy steps:
  • Increase the number of read/write samples from 2000 to 20000 (this will make your loop time nominally 100 ms).
  • Log all the waveforms to TDMS. Prove that you can do the experiment. Prove that you are getting expected data by reading and reviewing the data files.
After the easy stuff is complete, you may be able to call the code 'good enough'.
P.S. I don't think I have been forceful enough with respect to the logging...
Stop trying to write to 5 different text files in a loop that is struggling to keep up. Writing these text files is the slowest part of your code and gates your code performance. Your writing to disk code is also the messiest part of your code and makes the whole diagram harder to read and debug.
Doug
Message 30 of 38
(1,145 Views)
