New VI - default window size
Thanks for the idea. Ideally I'd like to avoid the requirement of adding the template to each and every project.
I wonder if this can be modified by editing some of the core project provider framework VIs/ LabVIEW VIs.
I've also noticed what appears to be a bug with VIs created using the override method (lv_new_vi.vi).
When attempting to add the newly created VI to the project using the App.Project.ActiveProject -> MyComputer -> AddItmFromMemory, it fails with Error 1004: The VI is not in memory. However, if I run the lv_new_vi.vi manually it works without any problems.
Message 11 of 13
(1,481 Views)
This works for me except I'm not able to save or save as the new VI, named Untitled 3 Front Panel, same as regular VI. I just got a 32" monitor and the LabVIEW new VIs are way too big :-).
cc
Message 12 of 13
(1,302 Views)
Please connect "App.DefaultApplication" to input "application refnum" of "New VI" to avoid problems when saving the VI.
Otherwise the new vi is created in application instance "NI.LV.PlugIN" which does not support save dialogs.
Message 13 of 13
(1,164 Views)
