01-15-2009 09:07 AM
There is Base version of Labview with Application Builder on "main" PC and one (can be more) PCs with NI-DAQ USB card without Labview
Executable VIs (Application Builder EXEs) should be developed on "main" PC and should be running on target PC.
Questions:
Can user control execution of executable VIs (on target PCs without LV) from browser (Labview web server)?
Or
Can VI access to NI-DAQ USB card on remote PC?
01-16-2009 04:15 AM
hellboy wrote:There is Base version of Labview with Application Builder on "main" PC and one (can be more) PCs with NI-DAQ USB card without Labview
Questions:
Or
Hello hellboy,
if you have activated the WebServer for the executable, it can be controlled through a browser. To achive this, be sure to enable the web server once in LabVIEW itself, and then copy the corresponding settings from the labview.ini file to the application's ini file (mainly the line "WebServer.Enabled=True"), or use the default ini file when LabVIEW's web server is active. Also remember to include the "www" directory with the HTML files into the application.
To answer you second question: you will need to have the DAQmx driver (or at least the DAQmx runtime) installed on the PC that the USB DAQ card is connected to. Then any VI or LabVIEW application on this computer can access the DAQ board. It is even possible to have the DAQ card connected to computer A and run a VI on computer B. If you have configured the measurement task on computer B and have the DAQmx IO Server running, remote PCs can request the measured data (max. 1kS/s per channel).
Sebastian
01-20-2009 08:01 AM
Another question with simple password security.
I found
http://digital.ni.com/public.nsf/websearch/427FE409FB11575686256DFF0008BBE4?OpenDocument
But:
1) Limit Access by IP - no
User can have dynamical IP
2) Programmatic Password Protection - no
VI has been published in Monitor mode (read-only)
3) Internet Toolkit Password Proection - no
We must buy it 😞
Therfore: Has Labview server internal simple password security feature as in Apache (.htaccess/htpasswd)
http://www.cyberciti.biz/faq/howto-setup-apache-password-protect-directory-with-htaccess-file/
01-20-2009 09:02 AM
Hi hellboy,
LabVIEW's web server is designed to provide a fast and simple way to monitor or remote control a VI application. As with many other parts of LabVIEW too, there are toolkits and modules available to upgrade the functionality. And one of the main features of the Internet Toolkit's web server is user authentification. Therefore, I expect there is no way to integrate password protection into the standard web server.
If you still fell that this functionality should be available to all users of LabVIEW, please file your request here: Product Suggestion Center
Sebastian
01-28-2009 07:21 AM
I have executable file MyVI.exe
I have started exe file, but server is not running!
http://localhost:8086 - is not accessible
Is Web server included in EXE file or this is standalone app?
MiVI.ini:
server.app.propertiesEnabled=True
server.tcp.servic="My Computer/VI-Server"
server.vi.propertiesEnabled=True
WebServer.TcpAccess="+*"
WebServer.ViAccess="+*"
DebugServerEnabled=False
DebugServerWaitOnLaunch=False
niwebserver.conf:
# Global Directives
ServerRoot "."
ErrorLog "./logs/error.log"
LogLevel 3
CustomLog "/Programms/National Instruments/LabVIEW 8.6/resource/webserver/logs/access.log" "%h %l %u %t \"%r\" %>s %b"
TypesConfig mime.types
ThreadLimit 10
LoadModulePath "./modules" "./LVModules" "./.."
LoadModule LVAuth lvauthmodule
LoadModule LVSnapshot lvsnapshotmodule
LoadModule LVRFP lvrfpmodule
LoadModule dir libdirModule
LoadModule copy libcopyModule
Listen 8086
# Directives that apply to the default server
ServerName default
DocumentRoot "./www"
Timeout 60
AddHandler LVAuthHandler
AddHandler LVSnapshotHandler .snap
AddHandler LVRFPHandler
AddHandler dirHandler
AddHandler copyHandler
DirectoryIndex index.html
KeepAlive on
KeepAliveTimeout 60
01-28-2009 07:27 AM
Firewall is off.
On the same machine I have Labview Base and Web Server works properly.
in the VI EXE directory is www direcory from
C:\Programs\National Instruments\LabVIEW 8.6\www\
01-29-2009 03:34 AM - edited 01-29-2009 03:35 AM
01-29-2009 03:56 AM
Thank you very much for sample!
It works!
There were problems in niwebserver.conf file
