12-13-2013 02:39 AM
Hello everyone (sorry for my english)..
I have this problem:
1 - I connected a network disk drive (x:)
2 - copy file from local to x: (with labview)
3 - All ok
but if the machine is restarted:
the copy not success
or better the copy success if I before I click on of unit X from windows.
Thanks in advance
12-14-2013 09:50 PM
Not sure I understand the problem. Also, not sure what you did.
The following should work:
At this point, the file copy on X: should exist, and should be persistent after you reboot. If this is NOT the case, then something might be seriously wrong with your Network Drive's hardware. Or your LabVIEW code is not doing the simple steps I outlined above. If so, post your code so we can see what you are trying.
