Need to understand a part of code
@altenbach wrote:
As I said before, I absolutely love the feedback node. You can cosmetically switch direction for better code layout, you don't need a dummy while loop for much cleaner code, and if you use the global initialization feature right, it can often eliminate the use of a "first call" primitive. You can place parallel FN in different cases eliminating tons of telephone wires (would even be better with this 11 year old idea, though. <hint, hint> :D).
Feedback nodes also don't have that abomination of resize-ability, leading to rigid code that never scales very well. Good riddance!
(Bob, not sure what a "feed-forward loop" is in the context of this discussion)
I'm pretty sure he's talking about the "switch direction" thing you mentioned above.  I can use a basic feedback node, and there are some instances - like when your subVI lies within a loop and you need the benefit of a shift register but have no loop to hang them on - where there are no alternatives, but I always have to experiment a few times to set it up right.  I imagine you can set it up without thinking, and frankly, it blows my mind.  😉
Bill
CLD
(Mid-Level minion.)
Message 11 of 13
(699 Views)
 Hey, 3 of your ideas made it into LabVIEW 2020 already, don't be greedy...
Message 12 of 13
(691 Views)
With feedback nodes, it is more likely to not notice certain mistakes (obvious in hindsight).
Message 13 of 13
(610 Views)
