10-13-2006 01:40 AM
10-13-2006 10:00 AM
This is a limitation of the ActiveX interface to Excel, and to my knowledge, there is no workaround for sending the entire large set of data. I recommend you use the Decimate 1D Array function (on the Array palette) to decimate the data before you send it to the Excel graph. Alternatively, you can start with an Excel template that already has a graph configured to contain a range of data from the spreadsheet, then just use the Append Table to Report VI to place your raw data in the configured range in the spreadsheet...I've never tried that approach, but I imagine a graph should update if new data is placed in its configured range.
-D
10-13-2006 10:05 AM
10-14-2006 02:25 AM
Darren
I understand the use of the Decimate 1D Array function to split the data set into smaller, manageable pieces, but then you have a number of decimated output arrays and I don't understand how you would reconstitute them into a single graph on the Excel side with the proper element order? If you called the Excel Insert Graph successively for each of the decimation output arrays, wouldn't it just produce multiple graphs? Is there some kind of interleave function built into one of the Excel graphing VIs?
I don't think I can use a preconfigured template graph because the size of the data set is always variable, as it depends on a date range specified by the user and the number of records per date is not predictable. Also, the user wants the ability to specify the file into which the report should be generated.
I would appreciate any further input you may have.
10-14-2006 10:25 AM
The reason I suggested the Decimate 1D Array function is that usually, when you're plotting something, you're looking at the overall appearance of the data. If you took an array of 4000 points that looked like a sine wave, and you removed every other point, the resulting 2000 points would still look like a sine wave...in fact, if you were viewing a plot of it, you probably wouldn't be able to tell a difference, given that your screen resolution is probably not greater than 2000 pixels in width, and the smallest amount of screen space your points can take up is 1 pixel. So to clarify my suggestion, you should try using Decimate 1D Array to divide the array into segments, such that one segment is less than 4000 points, then send that segment to your Excel graph. I don't know the nature of your data, but you can try it and see if there is any noticeable difference in the appearance of your graphs.
Note that if you're using Excel for anything other than visualization (like if you're analyzing the data in Excel), this suggestion is not appropriate. In that case, you may want to investigate the macro approach suggested earlier.
Good luck,
-D
10-16-2006 12:06 PM
<< This is a limitation of the ActiveX interface to Excel >>
This is a limitation of Microsoft Graph which stores the data array in the graph and not on the worksheet. The Insert Chart function uses MS Graph and not Excel to creat the chart.
As mentioned by Jhoskins, the best bet is to record a macro to create the chart and run it with the toolkit.
10-16-2006 02:00 PM
Right, the Microsoft Graph functionality has been used by the Report Generation Toolkit since version 1.0. We should probably evaluate other methods of generating graphs (if any reasonable ones exist) for a future version of the toolkit.
-D
