Need to combine 16 elements of 1-D array into one element without trying to use either shift registers and/or concatenate string?
Currently in my file i have a two arrays which i pass on to a second segment in which i combine every 16 elements of the array into one element. My array is of type string but is actually a binary number(0 or 1). I need to combine every 16 elements for one hex word. My constraint in the time in doing the logic. When i use the shift registers and/possibly or the concatenate string function the results for a large amount of samples take a very long time which i want to cut down. Attached is the file i am currently using with comments above the block that i need to change. Any help would be appreciated.
(4,098 Views)
I think you have attached nothing there!
By the way, to my understanding, if you only need to handle string array of 1s & 0s and obtain its hex equivalent. Attached method may be of useful to you, I hope.
ian.f k
labview@ianfung.net
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(4,098 Views)
Does anyone have an example of this I am trying to do the same thing, reading n elements of a 1D array and combining 16 of them together to make a hex value.
(3,558 Views)
Hi Nashm,
what's wrong with the example given more than 11 years before by ian?
(3,547 Views)
I had not converted the code properly for my use but having looked twice at it I have got it working. Now I am just trying to create a 1D array with the hex values
(3,534 Views)
You need to be much more clear. Nobody knows what you mean by "hex values", that term is very ambiguous and does not even define the datatype (formatted, binary, numeric, string, etc.).
Please attach a simplified version of your code. Create controls that have typical default values and create an indicator that contains the expected output. Make current values default before saving. Also please start a new thread so you can properly mark a solution.
(3,521 Views)
