Hi
Basically, if you use a separate vi to select the file, there usually is an output "cancelled". Wire this to a case structure, where the xml vi is in the false case.
If this does not solve your problem, post a picture of your code or the vi itself, so that we can have a look at it.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
