Need help
Create a new VI using a while loop where the random numbers between 36 and 54 are displayed on a waveform chart.
Create a moving average from the last 12 random numbers using shift registers.
Show the generated random numbers and moving average values of the same waveform chart.
Display the values of the generated random numbers and the moving average in separate numeric indicators.
this is one of assignment prob i am running out of time , have to submit it plz help me out
Message 1 of 9
(5,023 Views)
I guess this is based on a course, so you should have learned all the tools to complete it. First, have a look at your notes and earlier exercises.
Is there anything specifically you have problems with? Can you show us how far you got and where you got stuck? What is the main problem (e.g. creating random numbers? using a chart with two traces? Calculating a moving average?, etc...)
We are willing to point you in the right direction, but we will not do your assignment, because it would be dishonest to help you pass the course if you did not learn anything. Sorry.
Message 2 of 9
(5,008 Views)
Google LabVIEW in three hours
Message 3 of 9
(4,959 Views)
Hi Seacreature2002,
It would be very beneficial if you could ask more specific questions on which functions/concepts you are having difficulties with. If you include a picture of your code and a question regarding expected behaviour, more users will be inclined to help answer those questions.
Michael B.
Applications Engineer
Message 4 of 9
(4,925 Views)
I think I got it figure out now. Thanks for all the potential help though.
Message 5 of 9
(4,896 Views)
would you mind posting your solution and mark it as solved,
others may find this interesting.
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 6 of 9
(4,880 Views)
Accepted by Seacreature2002
regards
Not only that, but since this is an assignment, the poster could very well learn some things, or even get praise for a job well done!
Bill
CLD
(Mid-Level minion.)
Message 7 of 9
(4,876 Views)
Hi, I would like to have your recommendations.
I  wanna create a project based on signal processing. Simply I can say, it combines 3 parts. first one is signal generation, 2 one is filter design, and the last one filtering. My concern is about the memory, which way can be helpful for me to code, use of message handler or dynamics or any idea about it?  If possible, can you tell me how can I post in the community, because I can't find where to post, therefore I replied
I look forward to hearing from you soon.
Message 8 of 9
(4,804 Views)
you might want to start here https://forums.ni.com/t5/LabVIEW/bd-p/170
use the "Start A Topic" button right under the 'welcome to the labview support board'-header.
Message 9 of 9
(4,800 Views)
