Need help to build a battery test station
I replied through my email earlier but not sure it was delivered or not. Can you save it as 2013 version? Thanks again.
Message 11 of 17
(1,428 Views)
Accepted by AndrewZhu
Here you go saved to LV 2013.
This one will work better anyway as I replaced something that was deprecated in LV 2016 with the original vi.
=== Engineer Ambiguously ===
Message 12 of 17
(1,422 Views)
Thanks.
Message 13 of 17
(1,419 Views)
Hey there
Does someone know how I can open this .vi? I`m having trouble opening it.
Message 14 of 17
(1,034 Views)
Hi Petschi,
which VI are you talking about?
Which troubles do you have?
Message 15 of 17
(1,029 Views)
This first vi that was sent. When I try to open, the following window opens and it says in german: ignore object, ignore all, search and stopp.
But if it doesn`t work otherway a screenshot of the program would be fine too.
Or does someone have a simple batterie station program just to charge and discharge the batterie and showing the important characteristics of the battery?
Message 16 of 17
(1,026 Views)
Hi petschi,
that VI looks for some KE622x driver VIs: have you looked in the IDN (Instrument Driver Network, ni.com/idnet ) for those drivers?
When you want someone else do your jobs you need to post in the Job Offerings board.
Or better stick with your other thread!
Message 17 of 17
(1,022 Views)
