Need help on labview
I have 6.0 labview with NI-6023E and CB-68LP. My goal is to run some samples of prtein solutions using a light scattering. However, I don't a clue how to program to capture the a plot of intensity vs. time of the solution using a laser diode and a detector. So, if there is an easy way to do it that I can follow,let me know.
(2,536 Views)
Nirmal discussed the hardware interface in his reply to your other posting.
Look at the example that can be found under
Help>>>Find Examples>>>Hardware Input and Output>>>DAQ>>>Analog Input>>>General>>>Cont Acq&Graph (buffered).vi
That should get you started.
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
(2,536 Views)
