Need help in 1D search array
Why i always get -1 for the search 1D array here?? Attach my vi
The purpose is to get rid of the repeat numeric & store if not repeatable.
Thanks and Regards,
Simon
LV8.2
(2,995 Views)
In your example you try to look for 13 in array [ 3;9;5;8;1;23]. 13 is not inside => function return -1
Yoann
(2,977 Views)
Accepted by simon76
I'm not quite sure what you want to achieve, but your search array does return the index of the searched for number. However you search once for every time in the array, and the last time you'll start searching from the last element, thus always -1.
Is the idea to add the numeric to the array if it's not already present? Then it's overly complex (and not functioning).
Would these changes solve it?
/Y
Message Edited by Yamaeda on 01-27-2010 08:49 AM
Qestit Systems
Certified-LabVIEW-Developer
(2,976 Views)
Hi Yamaeda,
It solve my problem.
Thanks for your help.
regards,
(2,958 Views)
you can also have a look at this
(2,948 Views)
