Need help around writting and reading a control from web server.
So I'm having a problem when writting from a web server to a control. I'm trying to achieve writting from a global variable to a variable called "DO Lines" and I simply don't have an idea of how can I change a control via web server and also changing it manually over LabView. I can read the value of global variable over the web server, but I can't write to it so it changes the "DO Lines" variable input to the "NI Elvis Digital Writter". Any idea or example how to achieve it? I'm not an expert with LabView but every advice, help or example with help out a lot. If you want me to, I can post the whole project. I attached the first VI and the Write.vi and some .jpgs of the files there.
Thanks a lot!
Message 1 of 1
(2,104 Views)
