02-18-2009 10:51 AM
I just recieved my Q1 2009 software up date! As I go to install it(from the DVD), on a vista machine, with 8.6 already installed, I recieve th folling error:
" Error: Windows SDK function returned and error. (Error code -12) The Handle is invalid."
Any Ideas?
02-19-2009 11:15 AM
Hi Gene,
Are you still getting this error? Do you get the exact same error message every time you try reinstalling 8.6.1? Also, could I have a screenshoot of the exact error message that you are seeing?
02-19-2009 11:34 AM
Actually after rebooting and removing and reinstalling the disk a couple of times it worked. Maybe some sort of CD Rom drive issue? Thanks for you help!
02-20-2009 03:20 PM
02-25-2009 06:23 AM
I need simple to install 8.6.1 from new DVD - setup program must correctly upgrade 8.6 to 8.6.1
Do I need to reactivate Labview (I have Base version)?
02-26-2009 10:40 AM
Hi hellboy,
You will have to reenter your serial number and reactivate LabVIEW when you upgrade.
