Nanoscope II (digital instruments)
We are looking for a cheap labview-based solution for running Nanoscope II(SFM) by Digital Instruments. Our present problem is that the cards used to drive the instrument require 3 ISA-slots, and newer PCs only come with 2 or less of these. Has anyone tried developing a labview-based solution for the same? If so, could you suggest a suitable PCI-based card(s) for the same?
Thanks!
(2,859 Views)
Hello;
Could you maybe give us the specifications needed for the Data acquisition system?
With those specs handy I could give you a more accurate advise.
Regards
Filipe A.
(2,859 Views)
