NUMBER TO STRING, STRING TO NUMBER
THIS IS WHAT I AM TRYING TO ACHIEVE..
INSERTED NUMBER = 1
OUTPUT = 001 <I HAVE DONE THIS.. THE PROBLEM IS...
INSERTED NUMBER = 11
OUTPUT IS = 00C  <BECAUSE OF NUMBER TO HEXA STRING FUNCTION.
THIS IS WHAT I WANT TO APPEAR
011
AND SO ON   012........100....101
Message 1 of 18
(4,969 Views)
i need to know ur final data (001, 002,.. 010, 011,.. 100, 101,..) should be in number or string?
S Boopathy Raja
Message 2 of 18
(4,961 Views)
Convert using Number to Decimal String Function with width as 3
Then replace Space with 0,
Then you will get the expected Result.
Message 3 of 18
(4,957 Views)
Even Change of Properties of a Numeric Control/indicator will help you.
Message 4 of 18
(4,943 Views)
Post the code you have.
You're not describing if you're visualizing strings or numbers. That kind of things are pretty important for understanding your problem (and our answers).
Message 5 of 18
(4,936 Views)
INSERTED NUMBER = 1
Why use number to Hex String at all???
Use "format into string" with the correct "format string" and you are done:
Regards, Jens
Kudos are welcome...
Message 6 of 18
(4,929 Views)
Because...
Spoiler
it works on 1D arrays. And 2D arrays. And clusters. And Arrays of cluster. And cluster of arrays. And... Well, you get the point.
It's a bit faster too.
Format Into String is usually the end point, as it's much more flexible. But not always. I'd slightly prefer Number to Hex String over Format Into String, if it fits the job.
Message 7 of 18
(4,919 Views)
wiebe@CARYAFormat Into String is usually the end point, as it's much more flexible. But not always. I'd slightly prefer Number to Hex String over Format Into String, if it fits the job.
But it (ie Number to Hex string) does not do the job - in this case.
Message 8 of 18
(4,910 Views)
True, the Number to Hex String won't work if you don't want hex string.
The answer to "why use Number to Hex String at all", in the general context, still applies. (Just crawling back from my Friday afternoon mistake Smiley Wink).
Message 9 of 18
(4,904 Views)
Correct.  And the Number To Decimal String will fill the string width with spaces instead of 0s.  So Format Into String, or even Format Value, inside of a FOR loop would be the way to handle arrays to get what the OP is asking for.
Message 10 of 18
(4,903 Views)
