NUMBER CONVERT TO STRING
HI
  ANYBODY know how to convert a number to a string
  for example i need to convert number 1-9999 to a string, but the number below the 1000 in the string should display as 0900 for 900, the number blow 1000should add a 0 befor in front of the number in the string.
 can anybody teach me how to do it?
Message 1 of 10
(5,339 Views)
Read the Detailed Help for the Number to Decimal String function. It shows how to get a fixed width string.  Then you would need to replace the space characters with zeros.  Or use the Format Value function with an appropriate format string.
Lynn
Message 2 of 10
(5,337 Views)
hi
  I  have did what you suggested, but it does not works
  this is the vi
Message 3 of 10
(5,320 Views)
You did not properly read the documentation, or Lynn's response. What did you expect if you set a width of 0?
Read the help on the Format Into String function. Use %04d as your format string.
Message 4 of 10
(5,312 Views)
Accepted by topic author lilight
Like this
20837i858A0BCB03AF03C9
The VI below is in Labview 8.0
Tim
GHSP
Message 5 of 10
(5,298 Views)
@aeastet wrote:
Like this
What is it that they say about teaching a man to fish instead of just giving them the full course?
As for aeastat's code, it can be reduced to this:
Message 6 of 10
(5,289 Views)
Note to self: If you want your response marked as the solution make sure you provide a picture to go along with the answer, regardless of whether you explicitly stated the answer in the response. Apparently kids these days like that flashy stuff. Smiley Very Happy
Message 7 of 10
(5,273 Views)
Actually, what they really like is for us to do their coding for them.  I've succumbed to doing this a few times, but I try not to, and give them a description of what to do instead.  They usually don't like that.
- tbob
Inventor of the WORM Global
Message 8 of 10
(5,263 Views)
Most of them are allergic to the help files also.
Lynn
Message 9 of 10
(5,255 Views)
And allergic to the tutorials and shipping examples. Maybe a login to the forums could only be granted after completion of the new LabVIEW 101 tutorial. Id bet we'd see a huge drop in traffic.
Message 10 of 10
(5,243 Views)
