NImax.exe has generated errors. You must restart the program, a log file is being created.
being created.
This error occurs just after bootup, no programs started except windows..
Running Windows 2000 latest version on a brand new computer.
(pent 4 3.0 ghz 500MB ram).
Can anyone help me with this problem? Happened after install Labview 7.0
express. Installed twice and same problem occured with both installs.
Labview 7.0 is the only thing installed right now. Also selected "Visual
Basic Support" install from driver cd's.
One other thing I just noticed. System info reports 2 processors and I
think I only have one.
TIA
Message 1 of 10
(4,632 Views)
Since your processor use HT technology, system info will show you two processors. (it is virtual)
After install windows, try update window first from microsoft site, then try install LV again.
christmas Gift, brand new PC!!
Merry X'mas and happy new year
Best Regards,
maymaythar
Message 2 of 10
(4,632 Views)
Merry Xmas to you too and thanks for quick reply.
Unfortunately, I already tried that. Even reinstalled windows and all
drivers. Installed Labview three times. Still get same error.
Also, this is a Win2k generated error and it seems that the file it is
updating is "software.txt" under the Winnt folder.
I have the computer at home on a peer to peer network (no server) thru a
cable modem hub Looked at administrator alerts and I see one that says
" claims that is the master on the network..." this is one
of those red errors (higher level than a warning).
The computer with LV is not the computer that is registered with the ISP
(i.e.. specific computer name that ISP recognizes is not the one that I am
installing LV on.). Also, the LV comput
er is running Win2K and the other
computer is running XP. Would try installing LV on the other computer but
not enough disk space and don't really need it on that one.
LV installs ok with no errors but still gives me above error when ever
computer is booted up. Also, if I click on anything in "Measurement &
Automation Explorer" Win2K generates the same error.
Also, I have no DAQ hardware installed yet, just the comm ports that come
with the computer (no plug in boards except the single board computer CPU
pcb). Also, this is a brand new LV package received less than a week ago
(Prof Development Suite).
Thanks again, and anyone else who also might have ideas is also appreciated.
JJF
"Alexander J." wrote in message
news:506500000005000000AB470100-1068850981000@exchange.ni.com...
> then try insta
ll LV again.
> Best Regards,
> maymaythar
Message 3 of 10
(4,632 Views)
Happy cristmas & new year for you & ur brand new pc...
How are you uninstalling & then installing LV in your pc ?
I suggest to remove complete LV (Remove All option) from your computer. Once uninstallation is completed, go to windows registry - by windows start -> run -> regedit -> Enter
Goto HKEY_LOCAL_MACHINE-> SOFTWARE -> National Instruments - Delete this folder (National Instruments folder)
Remove any other foloder/file related to NI's software. Be very cautious while deleting files from windows registry bcoz wrong file deletion may hang your whole system.
Restart your computer..hope it should bootup without any errors.
Now as answered by Alexander, update windows.
After updating, bootup your system. If it boots up without any er
ror message, install LV with the typical (default installation).
Hope this helps. Your feedbacks are welcome.
Best Regards,
Nirmal Sharma
India
Message 4 of 10
(4,632 Views)
Hi Nirmal and all,
Happy Holidays to you too, and thanks for the reply.
Making progress. Did all the uninstalling and registry editing as you
suggested. Also, updated Win2K at Microsoft.com as suggested.
Re-installed with default settings of LV express 7.0. Now I only get the
error when I exit NImax.
Also, my p2p home network is not that hot. Have it set up as a workgroup.
Sometimes when I boot up I have file access between the two computers and
sometimes windows explorer can't find the workgroup network path (between
the two computers). Both computers can always access the internet though.
Using a 4 port Linksys cable/dsl router on a cable modem. Using XP home
edition on base computer (the one set up for the isp) and Win2K on the other
computer.
Also, any idea where this log file is going? Thought it was part of the
event viewer but the errors in the event viewer don't seem to correspond to
the NImax.exe logging event now. There is a file in
"winnt\sytem32\config\software.log" that seems to change at about the same
time but I can't access the file because it is in use by the system.
Using NImax ver 3.02.3005. Do you know if I can download "NI measurement
and automation explorer" and/or the driver cd's from NI.com? Maybe I have a
flaky disk or something. I have a feeling it may also have to do with the
"on again/off again" network neighborhood connection problem.
Thanks again,
JJ
"Nirmal Sharma" wrote in message
news:506500000005000000AE470100-1068850981000@exchange.ni.com...
> Hi,
> After updating, bootup your system. If it boots up without any error
> Best Regards,
> Nirmal Sharma
> India
Message 5 of 10
(4,632 Views)
One other point, I found out this is a message generated by drwtsn32. Can
get rid of the error by unchecking "show visual feedback on errors" box, but
don't like that fix. Still need help.
JJ
"JJF" wrote in message
news:%JRGb.138921$8y1.419649@attbi_s52...
> Hi Nirmal and all,
the
other
> computer.
to
a
> Thanks again,
> JJ
> > Hi,
> > Best Regards,
> > Nirmal Sharma
> > India
Message 6 of 10
(4,632 Views)
Happy update.
After ignoring this problem for awhile and installing some NI DAQ boards,
this problem is not happening anymore.
Would urge NI to investigate further though. Messed me up for a couple of
days, and still don't know why it happened.
Much thanks to those who helped.
JJ
news:qB6Hb.48702$VB2.90660@attbi_s51...
but
> Thanks,
> JJ
> > Hi Nirmal and all,
> the
workgroup.
and
(between
though.
home
> other
> > computer.
> to
same
measurement
have
> a
the
> > Thanks again,
> > JJ
> > > Hi,
> > > Best Regards,
> > > Nirmal Sharma
> > > India
Message 7 of 10
(4,632 Views)
Hi JJF,
Good to know that your problem has been solved....but not fully...
At the moment, I dont have any system to try for your problem..i mean installing windows & LV on new brand pc..
If i get any clue, i will surely get back to you.
Best Regards,
Nirmal
Message 8 of 10
(4,632 Views)
I will also disable the hyper-thread. LV is not quite compatable with
the HT. We have troubles with the computers with HT enable. It messed
up some event structures.
Happy new year.
Ho-ming
"JJF" wrote in message news:<4BDGb.653145$Tr4.1661862@attbi_s03>...
> being created.
ual
> TIA
Message 9 of 10
(4,632 Views)
There are times when your max or labview gets corrupted
Format your PC and start installing windows/OS,and install labview
All the best
Message 10 of 10
(4,631 Views)
