NIVISA installation cannot continue (MACOS 12)
I was trying to install NI-VISA 21 into MACos 12, however, the installation cannot continue, see attached pic below.
Additionally, I first installed  NI-VISA 22 successfully, but the GPIB ports cannot be found. So I deleted it from Application and tried to install 21 because I found here https://www.wavemetrics.com/forum/general/ni-visa-driver-mac-os-12-monterey saying 21 is the right version for this OS.
(1,210 Views)
According to NI-VISA Features and Operating System Compatibility, GPIB is compatible with NI-VISA 21.0 and earlier and not compatible with NI-VISA 2022 Q4 or later.
At the same time, based on NI-VISA 21.0 for macOS Readme, NI-VISA 21.0 for macOS supports the following platforms:
  • macOS 11.x
  • macOS 10.15.x
https://tmesystems.net/
(1,167 Views)
I use Windows, never MacOS so I can't be sure, but on Windows you need to install NI-488.2 to get GPIB working.
Looks like you can get the Mac version here:
https://www.ni.com/en/support/downloads/drivers/download.ni-488-2.html#441749
Apologies if you already knew that, but as you're a new member and it wasn't mentioned in your post at all.
(1,146 Views)
