NIScope CPU usage 100% when waiting for trigger
Hello, I'm using a NI 5102 DAQ card and want to acquire single bursts. However when the Multi Fetch.vi is waiting for a trigger (and this can be up to a minute) the CPU usage goes up to 100 %. Is there any way to overcome this?
(3,293 Views)
When I run the vis attached. I get the errors as to the vi is missing.
Also I would suggest you to use wait on ms option in the loop, where you carry out the task.This would enable A wait on the loop programmatically forcing CPU to process other system events when necessary between iterations of the loop.
Please do let me know if this helps.
Best Regards
Atul Wahi
Applications Engineer
www.ni.com
(3,292 Views)
Please accept my apologies for the reply I posted earlier.
I have seen that you have used the wait on ms option,as I suggested earlier.
I would be able to provide the feedback once I have been able to get all the missing vis.Please do let me know as soon as possible.
Best Regards
Atul Wahi
www.ni.com
(3,292 Views)
The missing vi.s are given below as follows:
1)ScopeSUB.vi
2)GeneratorDownloadSUB.vi
3)niScope multifetch measurement stats Peak to Peak.vi.
Please do provide me with these so that I could have a look into the whole program.
Best Regards
Atul Wahi
www.ni.com
(3,292 Views)
Yea, Ive noticed the same thing.  The niSope dll in the Fetch.vi grabs 100% CPU if timeout is larger than 1 or 2 seconds.
Has anyone talked to NI about this?  The problem is in that dll which is polling the PCI Scope Card.  That dll is not giving back any CPU if it waits for more than a second or two.
John Dailing
jdailing@charter.net
(3,171 Views)
