NIPMCommError NI Package Manager
I get the following Error when I start the NI Package Manager.
The Info at ni.com/info doesn't help.
When I try the URL http://download-preview.ni.com it seems the Server doesn't exist.
Are the URLs correct?
If not how can I fix them?
Thank you
G3W0
(10,030 Views)
Hi Wolfgera,
I hope this helps:
in the NI Package Manager/Settings folder and specifically in "ni-package-builder-labview-support-1-0-released.ini":
replace the above URLs in the mentioned .ini files to the following URLs should solve the issue:
http://download.ni.com/support/nipkg/products/ni-labview-ng/1.0/released
http://download.ni.com/support/nipkg/products/ni-labview-ng/1.0/released-critical
Please give me feedback if it helped.
Best regards
Richard
(9,953 Views)
Hi Richard,
The URL replacement helped.
Thank you very much for your solution.
Now I have a new problem.
The Packages.gz is missing. Where I can download it manually?
Best regards
G3W0
G3W0
(9,944 Views)
@Richard20 wrote:
Hi Wolfgera,
I hope this helps:
Best regards
Richard
Richard-
The updated URL worked for me, too.  Thanks!
By the way, these files were found at the location C:\Program Files\National Instruments\NI Package Manager\Settings on my computer.
(9,726 Views)
I am having the same issue, but the URLs are no longer available.
(6,575 Views)
Hi can you be more specific on how to locate the setting folder so that i can dropped the links in it that you mentioned?
(2,313 Views)
