NI9222 Overwrite Fault
Hello
I am using a Crio9012 controller with 9102 chassis. With a 9222 module I try to sample a voltage using one channel with high speed e.x 1 to 10 usec. I used the example given from NI. However, when sampling less than 100usec I get an overwrite error. Is there any explanation ? I attach the VIs.
(2,965 Views)
I am missing your module, so I have some problem reproducing you error. Could you send a screenshot of the error you're getting?
Regards
Luigi
(2,769 Views)
