How can I determine the center of a gaussian window?
I need to analyse a signal composed by 4 channels. I want to apply a gaussian window (and maybe try other window types too) with "window center" at different locations in the signal. Let's say that the signal is composed by 1000 points. I would like to apply different gaussian windows with center at point 100, 200, 300, 400, 500, ... Is it possible to do that?
Thank you!
(3,018 Views)
well, the Gaussian window and the Gaussian Monopulse vis are good starting points,  I would start with the window vi, but with a shorter length and add zeros before and after to get the full window with the peak at the desired position.
If
Greetings from Germany
Henrik
LV since v3.1
(3,004 Views)
