NI9219 Data output questions
Hi I am having an issue with the write to file using the NI9219, when i am writing the data from the daq assist both data will output into the excel file but i am also trying to output the time interval at which each set of data points were collected. I was able to do that successfully in the Thermistor Time resp VI but i am unable to do this action with the NI 9219 Module.
also the data does not concatenate in the correct column as well.
If anyone could lend a hand I would be greatly appreciative.
I apologize for the messy VI wiring ahead of time hehe 🙂
(3,275 Views)
You are missing a few basics here.
the ULx Driver is for controlling hardware DAQ devices offered by MCC
the 9219 is a cDAQ device from NI and uses DAQmx as the driver
They are not interchangable.
"Should be" isn't "Is" -Jay
(3,264 Views)
I understand that they are not interchangeable, but the method of collecting data is almost the same. Loading time as well as the data in the array i am trying to get three columns of data one for channel A one for Channel B and one for Time at each point of data was collected.
basically i need to collect the data on both channels as well as time and then i will manipulate the data to give me the output that i need.
thanks
(3,258 Views)
Use 1D Waveform and build timestamp array (Waveform palette)
(3,237 Views)
