NI9205 - Use the 3.3V digital out to drive a 24V relay.
I have run out of digital outputs on my cRIO hardware and found that there is a spare digital output on the NI9205 Analogue input card.
I am looking for a level shifter to allow me to drive a 24V signal into this timer relay:
http://uk.rs-online.com/web/p/time-delay-relays/7596634/
I have found some cheap arduino 3.3V relays, but they are a bit intermittent.
I need a device like a mosfet to take the 75uA 3.3V output from this NI9205 and change it to 24V.
I'm not having much look finiding a solution and electrical work is not my strongest area!
Has anyone used this output before?
(7,945 Views)
Hi David,
there are ready-to-use chips available, like this or that
(7,932 Views)
Accepted by david.ball
Have a lok at this one:
http://www.ti.com/lit/gpn/tpl7407l
but there are more... a digikey parametric search ?
Greetings from Germany
Henrik
LV since v3.1
(7,925 Views)
Thankyou I have ordered some of these with a small empty DIN rail enclosure, I'll try to give an update after the new year if I have success
Merry Christmas
(7,845 Views)
Electrical stuff is not my strong point.. Any idea how i get a 24V signal from this?
From what I understand I could connect a pullup resistor to 24V and a pull down to 0V. When the output is sinking i should get 0V and when it is not then I should get 24V?
(7,781 Views)
Hi david,
Sure! 😄
From "what"?
No.
We did suggest several options. Which one did you choose?
Do you have any schematics of what you want to create/solder?
(7,779 Views)
The schematic to drive a 24V relay is given in fig. 9  of the datasheet linked in the marked solution.
The output of the driver is a open collector/ open drain .
What type of 24V signal do you need exactly?
What do you want to connect?
No problem for a PLC input configured to read a OC signal. So tell us what you want to connect and we can tell you a solution 😄
A pull up resistor replacing the relay will give you an inverse 24V Signal. But depending on the device you connect it will be a 24V*(R_device/(R_device+R_pullup)  to 650mV Signal :).
Henrik
LV since v3.1
(7,770 Views)
