NI softmotion with EPOS2 controller example problem
Hello benjamin,
Can you share a screenshot that shows this error code, error source and the error message?
This would help me to see where the error is originating from.
Have you already tried the Maxon Motor support page?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 25
(2,499 Views)
Hello Thierry,
the screenshot below shows the Code which sets the Axis Interface of Soft-Motion in running-mode:
 If the "Axis Interface Running" is a indicator for the Interface in running mode.
The Input for the "Start"-VI is a constant which includes my both unbound Axis.
If I right click in my Project and select "Interactive Test Panel", i get the following Error:
The axis Interface is keeping on Running and promting no error.
I already tried the support on Maxon-Motor homepage. I will try your support channel.
Message 12 of 25
(2,491 Views)
Hello Benjamin,
This seems to be a user-defined error code.
In general this means that it is an error that is not "coming from LabVIEW", but rather an error that a custom application (purposely) creates and returns to you in certain conditions.
It think you should check with Maxon Motors what this used defined error is supposed to mean.
What feedback have they given you through their support channels?
Kind Regards,
Message 13 of 25
(2,479 Views)
Hello Thierry,
i got feedback from Maxon Motor, the answer is below.
The Error 0xFF0C is EPOS2 device error. Have a lookt at the document "EPOS2 Firmware Specification" chapter "Error Handling - Device Errors".
-> 0xFF0C: "Interpolated Postion Mode Error
For a more detailed error info, connect the EPOS Studio to the USB interface of the EPOS2 controller and have a look at:
- Status Window
- Object Dictionary -> Object 0x20C4-0x01 (Interpolation Buffer Status)
I assume its a buffer overflow, caused by a too high cycle time of the compactRIO master.
The description in the "EPOS2 Firmware Specification" can be found below.
In my programm, I do not use any Interpolated Position Mode of the EPOS2 device, so I think, that this Buffer Overflow is caused by the NI Soft Motion Interface itself.
I will contact the maxon motor support for further Information/Solution and I will try a little bit more programming, such as resetting the error after opening the Interactive test panel.
The firmware specification can be found under the following Link:
http://www.maxonmotor.de/medias/sys_master/8811528749086/EPOS2-Firmware-Specification-En.pdf
Thanks for your help. But I think I will try programming them with NI9514 hardware Smiley Indifferent
Message 14 of 25
(2,466 Views)
Hello Benjamin,
I think it would be interesting to see if we can find a set of steps to consistently reproduce the issue (after the reset has been done).
I think this would be mutually interesting for NI and Maxon Motor.
Do you have a fixed way to reproduce the error after having done the reset?
Kind Regards,
Message 15 of 25
(2,458 Views)
Hello Thierry,
I tried to configure a stand-alone Project which could reproduce the error. There, I realised, that I did not use the Maxxon-Motor Bitfiles the Bitfiles of another Project.
The Maxon Motor Bifiles are located under the following Link:
<LabVIEW>\user.lib\Maxon EPOS2\FPGA Interface\FPGA Bitfiles
There, I selected the appropriate Bitfile CAN cRIO-9114, and included it in the "Open FPGA-VI reference-VI" which is part of the EPOS2 Controller Example.
LabVIEW than tells me, that the data type after the "Up-Cast" function does not match with the input of the "CAN Initialize.vi"
I included a screenshot which shows this detail.
If I point on the connection, it sais that the source-type is [FPGA Interface] and the sink-type is [FPGA-Interface].
In the project, where I had the Maxon Motor interface running, I included another bitfile.
If you want to give me your Mail adress, I can send you the Projects if you want.
Message 16 of 25
(2,445 Views)
Hello Benjamin,
Just to make sure we are on the same page:
- Which version of LabVIEW are you currently using? (2010 based on your screenshot)
- In which version of LabVIEW did you originally make the project? (guess 2010)
- Does the original sample/example project still work correctly?
- Which version of MAXON EPOS2 are you using? (at my side I just installed for testing purposes version 1.1.0.15 on LabVIEW 2013)
  This seems to look relatively different compared to your screenshot.
Have you already contacted Maxon about this error?
Kind Regards,
Message 17 of 25
(2,440 Views)
Hello Thierry,
I use LabVIEW 2012 and did also make the project in it.
I included the example VI from Maxon Motor, could be that they used LabVIEW 2012.
The original example project, which can be found under this link: <LabVIEW>\user.lib\Maxon EPOS2\NI SoftMotion\Maxon EPOS2 SoftMotion Driver.lvproj  shows the same error.
I am sorry, but I do not know where to look up the Version I installed from the EPOS2 Software.
I will get a new version and try again. If that does not work, I contact the Maxon Motor support another time.
Message 18 of 25
(2,433 Views)
Can be they used LabVIEW 2010* I mean
Message 19 of 25
(2,431 Views)
Hello Benjamin,
To install the EPOS2 software I just went to the VI Package Manager and installed the latest version from there.
This then showed a version number in the VI Package Manager:
The reason I was asking about the versions is because your capture explicitely mentions 2010 bitfiles in the free labels.
Mine mentions explicitely LabVIEW 2013.
From where did you download/install the library?
Kind Regards,
Message 20 of 25
(2,420 Views)
