NI-XNET
Error code -1074384718 occurs when I use NI-XNET to create a SESSION. Do you know how to solve the problem?
(1,406 Views)
Error -1074384718 occurred at an unidentified location
Possible reason(s):
NI-XNET: (Hex 0xBFF630B2) The NI-XNET driver no longer can communicate with the device. Solution: Make sure the device has not been removed from the computer.
As suggested by the error code, check if the device is still detected in the NI MAX.
https://tmesystems.net/
(1,356 Views)
