NI-XNET error in labview
I am troubleshooting a 20-second timeout error on an NI-9866 LIN module in an NI-9181 cDAQ chassis. The issue appeared immediately after a series of system updates in January (Windows -is wt i feel like..).
System Setup:
  • Module: NI-9866 (LIN/firmware version - 18061914)
  • Chassis: NI-9181 (Ethernet cDAQ/firmware version - 1.1.0f0)
  • PLC: AB 1769-L24ER
  • Switching: A physical relay switches the LIN lines between two different baseplates.
The Issue:
  • Manual Mode works: When triggered manually (with a delay), communication is 100% stable.
  • Auto Mode fails: In Auto Cycle, the PLC triggers the NI-XNET session immediately after the relay switches. This results in a persistent timeout or bus error.
ERRORS from labVIEW and NI-DAQmx
  • 1074384887
  • 1074384886
  • 1074384855
(595 Views)
I will recommend try uninstalling the updates. Recently I have encountered a case where CANoe software crashes on launch after Jan 31 Windows update. The system restored after reverting the updates.
https://tmesystems.net/
(559 Views)
