NI VISA
I am using NI VISA  to detect my USB device (which is ATMEL ASF Board) ,so  i create driver following this  and when i open ni max to use my usb device it show1.PNG(bulk in pipe  = no pipe present)... any suggestion why ? beacuse it is causing an error.
i used usblyzer for same device and it shows correct bulk in pipe at 83h as it should be..
Message 1 of 8
(4,819 Views)
i am using NI-VISA Driver Wizard  to make driver of my  "ASF USB" (ATMEL  WITH
VID=03EB & PID=2423)  as shown in NI-VISA Driver Wizard.png  and you can see
(numberofopenpipes: 0) then i make a driver and  it successfully connect my
device then i open NI max  to test my usb device   ni max detect my device as
can be seen in  image (ni max1. png) and when i open visa test pannel it show
bulk in pipe= no pipe present ( as highlighted in (ni max 2.png) and if i set
these value  and apply changes it shows an error  which can be seen on (ni
max3.png)
NOTE: unzip attached image.zip folder  to see all referred images.
what can i do to get my device to properly work with ni visa?
i think NI visa is showing (numberofopenpipes:0)  that's why i am having this
issue.
how  can it be resolved ?
please provide a possible solution as i am stuck with it for nearly 2 day.
i have tried my USB device with other driver  and software and i was working.
Message 2 of 8
(4,779 Views)
can anyone assist me with this problem ?
Message 3 of 8
(4,740 Views)
i did not set pipe in& out.
May be you can try it.
https://forums.ni.com/t5/Example-Code/VISA-List-all-VISA-Devices/ta-p/3504571
Message 4 of 8
(4,728 Views)
thanks 回應,
but this vi show the information of devices connected and not the solution of my problems .
Message 5 of 8
(4,691 Views)
Hi Shaunmarsh123,
Which OS are you using?
If you are using Windows 8 or 10, then I recommend looking at the article below.
Using a *.inf File from the Driver Development Wizard on Windows 8
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019L9QSAU
The only difference for Windows 10 will be that you need the Windows 10 WDK instead of Windows 8.
Jared T.
Message 6 of 8
(4,671 Views)
i am using windows 7 .. now what should i do ?
Message 7 of 8
(4,647 Views)
Have you walked through this Tutorial to ensure you set up your driver properly?
USB Instrument Control Tutorial
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1qzCAA&l=en-US
Jared T.
Message 8 of 8
(4,633 Views)
