NI Softwares not working in LabView
Hi all,
I just wanted a piece of advice. What happen is, I'm using LabView and I need Vision Builder and Vision Assistant functions in LabView which I was able to use, for ex: "Extract Single Colour Plane" or other features found in these two NI tools. But I have had a few problems recently, I therefore had to uninstall some things and install others. Know when I want to convert a file from Vision Builder or Vision Assistant to LabView, it doesn't work anymore, it shows me icones with a question mark on them, as in the attached file...
If you could give me a hint of how to resolve that, it would be very usefull 🙂
Cheers
Xavier
(2,956 Views)
That sounds like you uninstalled functions you were using.  You need to figure out what those functions were and what toolkit they were from.  Then reinstall the toolkit.
(2,937 Views)
right, I knew that haha, what I was asking was precisely if anybody could help me figure out where I could start looking at.
here is an attached file of the license manager
(2,930 Views)
You need to install the correct libraries again (maybe installing their toolkit is the solution).
Kind of off-topic, but why in the world your clock is showing 10/04/2013?
Hahahha that's weird.
Mondoni
(2,923 Views)
good question, not entirely sure haha
Anyways ok, I'll just try and reinstall all the tool kits. So are VAS, VISA, VDM... part of tese?
(2,920 Views)
Exactly.
That will be a bit boring but I think it's necessary.
Mondoni
(2,916 Views)
