DSP48E issue
Hello ,
              i have problem that am using RF communication library 3.0.In that when i place MPSK demodulator vi i get an error "subvi not executable and polymorphic subvi not executable".when i go inside into subvi's.DSP48E connection to controls and indicators has broken wires .i have checked that in labview 2011 and labview 2011 SP1 .i get same error.so please any one knows about this issue.
thankyou verymuch
Message 1 of 11
(4,526 Views)
Hi Jadoon,
Are you using LabVIEW FPGA? If so, what version?
Also, by MPSK Demodulator.vi, are you referring to this community example? According to the requirements, you need to use a PXIe-7965R or PXIe-5663 or later. According to the LabVIEW Help for the DSP48E, this can only be used on a Xilinx Virtex 5 or 6 FPGA. Does your hardware meet these specifications?
If so, please include some screenshots of which VI is broken and what the error message for the broken wire says so we can troubleshoot further.
Thanks and have a nice day.
Josh Y.
Message 2 of 11
(4,507 Views)
Hi JOSH,
      thankyou for reply.yes i am using LABview FPGA 2011 SP1. i am using this community example.In this example it is using 5641R that is virtex 5.When i place the MPSK demodulater.vi from RF communcation library i get the same error which is attached.
thankyou.
Message 3 of 11
(4,494 Views)
Hi Jadoon,
That is the hardware the example calls for, but what hardware and FPGA are you using?
Also, is it possible to see the error within the subVI? Sorry for the confusion. What I suspect may be happening is that LabVIEW does not know this is an FPGA VI or is searching in the wrong directory for the RF Communications Library and/ or the 5640R driver.
Regards
Josh Y.
Message 4 of 11
(4,479 Views)
HI JOSH,
             i am using the same hardware and FPGA i.e 5641R and xilinix vertex 5.i think is the issue of mutation of controls.i also checked in the known issues of DSP48E it says this issue is resolved in Labview 2011 SP1. I am using labview 2011 SP1.Actually when i open the FPGA vi of this example some of the controls the Vi doesnot find. so i browse them these controls are placed in obsolete folder( C:\Program Files\National Instruments\LabVIEW 2011\vi.lib\rvi\FXPMathLib\basic elements\DSP48E\Obsolete) in labview 2011 SP1.
thankyou.
Message 5 of 11
(4,467 Views)
Hi there, have you tried this on LabVIEW 2010? ...it seems that both the 5641R driver and the RF communication library 3.0 does not support higher versions.
Alejandro C. | National Instruments
Message 6 of 11
(4,445 Views)
Hi, have you solved your problem? I meet the same problem as you , I used Lv 2011 and RF communication library 3.0.
Message 7 of 11
(4,405 Views)
Hi,  Alejandro,  do you mean the LabVIEW FPGA RF Communications Library 3.0 do not support lv 2011?  I have the same problem as jadoon  , you can see it in the attachment.   thanks
Message 8 of 11
(4,403 Views)
HustLiliAn: I believe your problem is a bit different. You are connecting terminals of different data types. Try to make the boolean controls into fixed-point.
Message 9 of 11
(4,378 Views)
    sorry for little late reply. I had fixed point broken controls (i also had boolean broken controls so i uninstalled and then installed communication library) .so their are two ways how i solved it.one you go to the frontpanel and right click on each control that is broken then you will see disconnect from data type define.this will solve this issue or secondly you can remove the controls in the again create them and then save it.it will resolve it..
hopefully it will solve your problem.
thankyou.
Message 10 of 11
(4,360 Views)
