NI PXIe 7965R for emulation
I want to develop applications for NI Flex RIO PXIe 7965R in emulation mode as I don't have any hardware connected to my system but while creating FPGA project I am selecting create new system under which only PXI- 795xR series is available. How can I get the PXI-796xR series targets for my project?
As after testing in emulation mode I will run this applications in other system where PXie 7965 FPGA board is connected, so that I can directly export the project to other system otherwise I can export only the VI's where I should create new project under which I should add necessary memory elements each time.
Thank you,
Chandrasekhar R Patlolla.
(3,032 Views)
Accepted by topic author patlolla
I got the solution to the problem by updating  to NI RIO 3.3.1 which can be found using the following link
http://joule.ni.com/nidu/cds/view/p/id/1528/lang/en
Now I can find PXIe 796x series boards for emulation.
Thank you.
(3,008 Views)
