NI OPC server and DSC module
Hello
        I'm using LAbVIEW8.2.1 and I need connnect LabVIEW(PC) to PLC with Modbus. Please advise the belows
        1. What module is required?(I'm not sure DSC module)
        2.The NI(IA) OPC) server is require?
        And I have little confuse what is the relation between DSC module and OPC server
Thank you
(2,893 Views)
There are two things required
1. Connecting to PLC from PC - You need a OPC Server (NI or Non NI); Check the OPC Server has driver support of the PLC.
2. Getting the PLC Status to LabVIEW from OPC Server - You need NI DSC module to create a OPC Client which can Read/Write the status from NI OPC server.
(2,843 Views)
If the device uses modbus, then you can use the Modbus Library in your LabVIEW program to communicate with the device.
(2,838 Views)
