NI-Motion incomplete?
I am in the process of moving an NI-Motion based test rig from and XP based PC to windows 2010 on a fresh PC.
I have installed NI motion, but the project is failing to see flex motion VIs as follows:
C:\Program Files (x86)\National Instruments\LabVIEW 2017\vi.lib\Motion\FlexMotion\FunctionVIs\Tragectory.llb\Reset Position.flx\Inp Vect
I haven't found it on the original PC either, so far.
   Any ideas as to why this would be the case?
            Theo
(1,210 Views)
You can check compatibility here.  There is also a link to check OS Compatibility.  The last version of LabVIEW that supports NI Motion, I think, is 32-bit LabVIEW 2018 (you must be running 32-bit LabVIEW to use NI-Motion).
(1,174 Views)
Hi Thanks for your help,
 By experimenting I found that I need to install Motion 5.2 and then Motion 17 for it to work.  It looks like 17 doesn't included all the old Flex Motion VIs.
  Regards,  Ian
(1,120 Views)
