NI MAX stuck at loading plugins
Hello
I have installed LV 2016, MAX worked.
Next I installed NI Serial 15.0, MAX worked
Next I installed NI Visa 16.0,   MAX worked
At the end I installed NI Daqmx 16.0, MAX stuck at loading plugins.
So can you help me with that. I need all those drivers.
In may 2016 I was using LV2013, and there was no problem till august. In august this trouble happened and I solved it with installing new LV2016 with all those listed drivers. Then at the end of august the trouble happened again and i solved it with deinstalation/instalation of LV2016 and all drivers. Now this trouble happened again and I can not solve it any more.
I am fristrated with this, please help me.
Marko
(5,151 Views)
Hello
After few days I solved the trouble. I instaled NI DAQmx 9.8. I read this thread:
http://forums.ni.com/t5/LabVIEW/NI-MAX-crashes-at-load-plugins-following-NI-MAX-update-to-14-x/td-p/...
Probably the isue is that I have 64 bit OS and 32 bit LV. Maybe there is isue with newest driveres and support???
Can anybody confirm this or there is another issue?
Best regards
Marko
(5,130 Views)
-What version(Windows 7,8,10 or any other) with bit type (32 or 64)of Windows you are using?
-Check after installing DAQmx drivers if corresponding folder is created in C:\Program Data (Check if it is hidden)
- Try changing the read/write permission to that folder and see if it is still same.
- Source: http://forums.ni.com/t5/Multifunction-DAQ/NI-MAX-stuck-at-load-plugins/m-p/1312107/highlight/true#M6...
uday
(5,118 Views)
Hello
I just realized that LV 2016 does not support DAQmx9.8 drivers. So It was probably working because it was not supported, but now I need VI from DAQmx 2016.
So the problem is still here.
I have installed:
- Win7 64bit
- LV 2016 32 bit
- NI Serial 15.0
- NI VISA 1600
- PC is: HP Elitebook 850
I am addministrator on this PC, so I have all permissions. But when I right click on folder:
C:\Program Files (x86)\National Instruments
under attributes the checkbox: Just for reading, is checked.
If I try uncheck it, I can, but if I rightclick again this checkbox is still checked. The IT department of our company says that this is not impotrant aslong I have NTFS file system. I am not sure about this, but I am in administrator group.
If I rightclick and go to security tab, there I have all permissions.
For me it is strange that it was working for some time, and now it is not working any more.
I need NI DAQmx for connecting to NI cDAQ-9184 chasis.
I appreciate any help
(5,043 Views)
Here is printscreen of National Instruments folder
(5,042 Views)
