NI MAX Devices and Interfaces cannot be reight-clicked and create a new connection
When I tried to right-click the devices and interfaces bottom to create a new connection, there were no reaction. I have already installed NI Visa 15.0.
Thanks a lot for your help.
Best Regards
Da Shi
(2,632 Views)
Best Regards
Da Shi
Expand the software tab.  I don't think that you have NI DAQmx configuration support installed.
"Should be" isn't "Is" -Jay
(2,621 Views)
Thanks a lot for your answer. You are right about that I didn't install the NI DAQmx configuration support.
I'm not using the NI hardware, and I'm using Keithley Equipment. Do you think that NI DAQmx should still be installed?
Best Regards
Da Shi
(2,608 Views)
@DaShi1l be installed?
Best Regards
Da Shi
Every Keithly manual has a section on "Using Keithly with NI VISA..."  There is something that you need to do in MAX.  I forget the exact words.
(2,602 Views)
