NI I/O Trace closes immediately at startup
On an XP PC with LV2012 SP1 we installed an executable built with LV2013 SP1 and updated MAX (to 5.6) and NI-Motion (to 8.5.1). The issue is: An executable using the 2012 SP1 f5 run-time engine doesn't work anymore, it closes a few seconds after starting (the window never maximize). The same applies to NI I/O Trace (we tried to launch it to see if we could see something). The 2012 SP1 f5 run-time engine appear in MAX software list.
Note that the development code in LV 2012 SP1 is still working, We tried to redo an executable but it's not working. In the to do list we will try reinstalling MAX.
Any idea?
Ben64
(3,039 Views)
wow! that is so wiered, check the post i just made- exactly the same!!!!!  now i feel NI must take note.  Between us i hope we find an answer.  Im in UK so definatley time for me to give up tonight, see what tomorrow brings.
Kind regards,
Michael
http://forums.ni.com/t5/LabVIEW/repair-labview-runtime-LV2012-SP1-F7/td-p/2830454
(3,014 Views)
Kind regards,
Michael
A coworker will contact NI today. I'll inform you if we find something.
Ben
(2,980 Views)
I have an open SR too. Their best guess so far is uninstall evertthing 2013 related until the lv2012rte gets uninstalled. Then try again step by step. Im waiting for a better answer though!
Michael
(2,975 Views)
Ben,
I got a reply from NI with an installer for LV2012 SP1 F7.  I ran this and all seems to be well once more.  Sadly, before i recieved this i went through the pain of uninstalling and replacing my entire LV2012 and 2013 suite.   How are you getting on?
MIchael
(2,932 Views)
@Michael_78 wrote:
Ben,
MIchael
We didn't find a fix and decided to use the development code (it's for internal use). We tried to reinstall RTE 2012 SP1 f5 but it didn't fix the problem. After the testing is over I will probably spend some time on this to try to understand what happened and to avoid it in the future. Thanks for the follow-up.
Ben
(2,916 Views)
