NI-DAQmx 17.0.0 installer hangs
When I try to install DAQMX,the installation crashes and shows me the error in the pic.How can i resolve this issue??
(3,571 Views)
Is this a fresh install?  If you already had older drivers installed it can corrupt you install files. I usually remove the older version before installing 17.0 specially if they are version 9 or older.
(3,542 Views)
I don't have any older version of Labview
and yes it is a fresh install
what are my other option to make the daqmx installation work?
(3,532 Views)
The drivers requier .NET framework. Repair the .NET in windows or try uninstall and reinstall, then try installing drivers again(remove whatever is left of the DAQmx driver before reinstall).
(3,530 Views)
