NI-CAN
Hello all,
 I'm using the frame API on the NI-CAN 8473 hardware, I dont have a problem to analyze the data.  However i have a small problem, i need to add a control that will help specifying the number of samples to retrieve.  for example i need to read 100 CAN frames and stop. thank you.
Best Regards,
Hassan Badawi
(5,124 Views)
Accepted by topic author hassan.bdw
Hi Hassan,
some pseudocode:
repeat
  get CAN frame data
until number of CAN frames >= 100
Looks quite easy!
If you need more/specific help you should attach your VI…
(5,109 Views)
Hello GerdW,
do you mean to do something like the VI i've attached?.
Thank you.
Best Regards,
Hassan Badawi
(5,099 Views)
Hi Hassan,
something like your VI.
I would actually collect the data in a (2D) array - right now you only get the last frame data when your VI finishes!
(5,091 Views)
Posting from mobile so I haven't opened your VI. You should use ncReadNetMult to read multiple frames, instead of putting a single frame read in a loop.
(5,054 Views)
Hello all,
Is it possible to send multiple messages having different arbitration ID periodically (messages may have different periods) through single CAN
interface
(4,774 Views)
(4,762 Views)
