NI 9853 reads same message multiple times
When i tried to read on NI 9853 CAN 0 port, it will always reads the last message if there are no messages on CAN bus.
I have attached screenshot on my code.
In the code read counter is 0 unless i dont send any message on CAN, When i send single message on CAN(using other tool connected to same can bus), read counter gets incremented by 1 on every 10msec. I check all CAN message everything is same, Mod1/CAN0 somehow reads the same message every 10 msec ..
Attached CAN log also.
Thanks in advance.
Best Regards
Sumit Memane
CLAD, CTD
(2,860 Views)
Hi sumit,
how do you create this logfile?
Mind to share code?
I never noticed such behaviour with a NI9853...
(2,832 Views)
Accepted by topic author sumit04
On the read side of the FIFO you need to act on the timeout. The FIFO returns the last valid data on a timeout. Maybe that is your problem.
(2,824 Views)
hi GerdW,
I have a vi, which contentiously reading CAN message from NI-9853 Mod0 and writing it to ASCI file.
Best Regards
Sumit Memane
CLAD, CTD
(2,776 Views)
Hi
Best Regards
Sumit Memane
CLAD, CTD
(2,772 Views)
